Limit of Bends in Flex Conduit
Better to run the types with the wire inside already(mc). At least for now there is no restriction on bends with that. But in time there will be, cause thats how things work.
That's 'cause it's a cable and not a raceway.
Actually, MC may have a minimum bending radius. Anyone?
I don't understand 348.60 for FMC or 350.60 for LFMC re: grounding and bonding.
Why would you use flexible conduit if flexibility is not required, what is flexibility, and what exactly determines when flexibility is required?
yes it does. off the top of my head it's x amount times the outside diameter
Thank God you're here! :rolleyes: :)D)
(Meaning: "Duh! Of course it's something times the diameter!" Also, I'm just funnin' ya. :smile:)
