Did a service call today where the previous electrician installed a magnetic switch to control low voltage led tape inside a cabinet in the kitchen. The magnetic switch is attached to the door and the cabinet. The magnetic switch I removed was labeled as a magnetic security switch. I believe The load is WAC 24 v LED tape light on a 60 watt driver. I believe the load was to much for the existing magnetic switch as the switch was melted. Any suggestions on a different type or brand of magnetic switch or a limit switch?
