Greetings all.
Have a limit switch on a water valve with only two terminals for the switch contacts. The metal enclosure does not have a ground screw or terminal. It is an old limit switch that was connected with metallic sealtite. We have reconnected with non-metallic sealtite and the consultant has questioned that there is no ground termination. Any thoughts on what we should do.
Thanks in advance.
Stu
Thanks in advance.
Stu
