I heard that the NEC is going to add a new requirement to either the 2005 or 2008 code that will require a new type cable for use in plenum ceilings. The new cable, "CMP-50 cable" is insulated and jacketed with (FEP) Fluorinated Ethylene Propylene. It replaces flame retarded PVC as the jacketing material. I heard that it's also ten times more expensive then existing cables. Has anyone else heard anything about this?
