- New Jersey
- Journeyman Electrician
I have a 30 HP fire pump in the machine room on the top of the building. Local code calls this a limited service fire pump. Information is somewhat limited and this is not mentioned in the NEC, what is the actual application of these fire pumps and how do they differ from a standard fire pump? Here's the local definition as it applies to the electrical code:
Limited Service Fire Pump. For the purposes of this section, a Limited Service Fire Pump is a fire
pump located above street level with a motor rating not exceeding 30hp and connected to a limited
service fire pump controller.
