ABoshant
- Bakersfield CA US
I have a solar back feed that we are tapping into on the load side that has a 400 amp main but the load side is in parallel (2x 2/0 per leg) the back feed will be protected with a 60 amp fuse disconnect. In order to tap it would I be tapping to one or both wires that are running parallel?
Second question. On a line side tap of a 600a would I need to match the wire size to pull to a new panel we are installing that has a main disconnect of 200a Or would I be allowed to tap onto it with wire that will be rated for 200a?
thanks
thanks
