I have a line voltage switch pack that is used to control a lighting load from a low voltage occupancy sensor. The switch pack will be located inside of a junction box with both class 1 and class 2 wiring in the same box. Can I run the low voltage occupancy sensor wires in the same pipe as the 277 line voltage wires if I use 600v rated wire? Reading section 725 I'm believing that I can but just need to reclassify the class 2 wiring as class 1 wiring. What do I need to do to reclassify this wiring. Just relabel the switch pack as class 1?
