If a feed with parallel conductors is used, is it possible to use a connection for the load using a single conductor, or vice versa?
Applied to meters cans, disconnect switches, or any switchgear.
In my opinion it is possible, as long as both are rated for the same amperage, but I would like to know if the NEC says anything about it.
We could extend the question even if we used different material at the input and output, such as copper vs aluminum; or if we used a different size of wire.
In summary, can the input be different from the output in configuration, size and material as long as they satisfy the desired amperage?
