Line reactance and voltage level
I know two ways voltage and reactance.
1. You can find voltage and reactance relationship in cable catalog and appropriate voltage drop and ampere capacity calculation and consideration.
2. You can find voltage and reactance relationship through calculation
Suppose you know the voltage and you want to find line reactance for selecting a cable according to reactance. In this case, you can select transposed line and distance between conductors.
Through this formula you can find
L = 2*10^-7ln(Deq/Ds)
X = 2*3.14*f*l km/ph
there are many methods hope others will explain more clearly for you.
Mmmmmm, I got what you mean.
to increase voltage level ofcourse current decreases and since current decreases you can select small size of conductor
Indeed, reactance depends on cable size larger cable smaller reactance and resistance. Smaller cable larger reactance and resistance.
So, when you decrease voltage, current increases and you have to select larger cable size. Larger cable size has smaller reactance.
