TrickleCharge
- CA
I have a PV system in a commercial building where they are doing a line side tap. They come out of the top of the switchgear with EMT and run overhead on a unitstrut trapeze with EMT (approximately 20 feet) to an AC disconnect. My understanding is that these conductors are required to be protected from physical damage per 230.32. This references raceways installed "outside the building" per 230.6 and the use of an approved raceway per 230.43. My questions is, can they install this as described or should it be "outside the building"?
Thanks
Thanks
