Hey guys, I'm probably over thinking this, but want to double check myself. Have a shop to light, panel is on one side of the room, door is on the other side. Normally I try to avoid putting my line in the same conduit as my switch legs to avoid heating. This job would work better to put them all in the same conduit. But didn't know if that's a good idea or if I should run a dedicated pipe for my lines, to the switch box, then back up to the lights. There will be 2 circuits, so in my 3/4 emt there will be 2 lines, 2 switch legs, and 2 neutrals + ground. Thanks in advance!
Edit - each circuit is looking at a 14 amp load.
