David Goodman
- Pahrump, NV, USA
I have a fan control pressure switch that for time savings and reduced cost would best be installed outside of a heat pump condenser unit at the suction line service valve. The switch goes in series with the fan control from the defrost control board. So, it is carrying one leg of 240V for the condenser fan motor.
The wires are marked as follows:
E172774 AWM STYLE 3175 XL PE 600V 125˚C 18 AWG LL84983 ....
Parts of those marking I understand.
Is there a code accepted way of installing this outside the condenser unit and running the wires inside?
If there is, then please point me in the right direction. It would cost several hundred dollars more to install it inside the condenser unit.
