Arch
New member
- South Carolina
With so many VFDs these days having bottom feeds for power and output, is there anything that prevents a designer from feeding power distribution and fuse blocks from the bottom up in a control panel?
An example would be 6 40 HP VFDs that each have a 3-pole fuse block below then, with a PDB below that which is connected to the panel main disconnect switch.
