Linking Tra-Ser Premier and Accubid databases for auto update
Fiasco
I just set my employer up with TRA-SER premier and they have BidWinner/Accubid.
I'm trying to set up Tra-Ser to automagically update my Accubid Database.
What I have done:
(Accubid)
Accubid TRA-SER Setup program
Set my database directories
Under Service - Price service is dataselect/traser electrical
Price Column - Col3*
Matching Code - Price Code
Selected my database (ACCUBID ELEC USA NECA IMP DB)
checked DO NOT PROMPT FOR DATABASE
checked AUTO CLOSE APPLICATION AFTER UPDATE
closed program with OK button
(Tra-Ser)
Started TRA-SER admin program
Under updates available tab
Electrical Full listed
And "Error reading D:\Program Files\Accubid\V9\Accubide.UPD"
Under Link Settings tab "Installed Link Applications" box I also have the above error listed.
Fiasco
For those that run into this problem here is the cause/solution.
On my work PC the operating system is installed on the D drive. So is traser and accubid. The problem stems from the fact that the TSP folder in traser is installed on the C drive. Within the traser program itself the program will correctly reference the D drive traser is installed on for the TSP folder (D:\TSP) but traser will still put the TSP folder on the C drive.
Update traser admin program to C:\TSP for link files and problem solved.
