milmat1
"It Can't Do That !"
- Siler City, NC USA
- Controls Engineer
I keep running into the same argument with different people. Over the use and restrictions involved in using liquid tight metallic flex, (LFMC)
We are an OEM that builds custom machinery for several industries.
I often use liquid tight flex around and on machines. I also will sometimes use this flex to run from a free standing control panel over to the machine, usually into a large J-box or smaller control panel etc that is mounted on the machine.
My question is what are the limitations of using LFMC Liquid tight flex ? I cannot find any limitation on length of flex, unless you are using the conduit as a ground conductor. But as for running it from the panel to the machine, or just general use I can't find anything?
The project that presently brought this question up again is one that will be installed in a wet location. Any additional restrictions there ?
As I said we are an OEM and build an engineered product so we have very few limitations however we do want to stick as close as possible to the NEC as a general rule..
