Liquidtight flexible metal conduit
relbas
Can I penetrate the roof and use liquid tight as my wiring method?
If I can not do that, which section of the NEC prohibits me of doing so?
Thank you.
[ August 01, 2005, 03:09 PM: Message edited by: relbas ]
Re: Liquidtight flexible metal conduit
I would think that "protection from liquids" would include rain on the roof.
If you are speaking of penetrating the roof, I believe most inspectors would nail you with 350.12(1) "Where subject to physical damage" Just a suggestion, but to save yourself from doing it over if the inpector sees it, penetrate with pipe.
I think that if you penetrate the roof with pipe and then switch over to LFMT it should be fine as a wiring method, as long as it's installed to meet 350.20 through 350.60.
We have used LFMC through a roof where the roofer supplied a pitch pocket which is about 6" above the roof and allows for waterproofing. The pocket should provide protection for the LFMC but as others have noted a conduit penetration may be better.
Will rain damage LFMC? :confused:
350.10(1) does not mean that the liquidtite requires protection from liquids, but that it "shall be permitted" where conditions require protection from liquids. The sealtite protects the conductors.
I also have penetrated a roof with sealtite when a pitch-pocket was provided. But I would not use it with just a "witch's hat" type of flashing.
John
