generally not, and since they are not usually part of an installation, they are not usually covered by the NEC. however, there are at least a few appliances that the NEC requires be listed. the NEC only requires things to be listed that it specifically requires to be listed.Question: Is there any State, Federal, or NEC requirements that cord and plug connected equipment or appliances sold in the US are required to have a NRTL listing?
OSHA has some often violated requirements that equipment available as listed has to be listed, but it only applies to OSHA situations.
In any case, none of these restrictions prohibit the sale of unlisted anything. There are some cases where an unlisted appliance can't be used, but AFAIK, there are no cases where they are prohibited from being sold solely on the basis of lacking a listing.
If your question were slightly reworded to ask
"Is there any State, Federal, or NEC requirements that all cord and plug connected equipment and appliances sold in the US are required to have a NRTL listing?"
The answer would be no.
There are some cases where some equipment and/or appliances are required to be NRTL Listed.
If you tell us why you ask, we may be able to provide a more suitable answer.
The closest thing I can think of, in terms of regulatory authority, would be CPSC. If they chose to set a standard for a particular product they could choose to adopt an applicable UL standard.is there any requirement anywhere that says you can't SELL something just because it is not NRTL listed?
you may not be able to use it in a code compliant way, but that does not mean it cannot be sold.
