tilden
- Chapel Hill, NC, USA
I have an AC/DC power supply that's UL listed and outputs max 60W at 24VDC, so below the 100VA max to I believe be considered Class 2 (NEC 2023 Chap. 9 Table 11(B)). If I put this in an enclosure in a building, or outside, do the conductors I'm connecting this 24VDC output need to be "listed" (UL, ETL, etc) if I run them from the enclosure to another piece of equipment (sensors, cameras, etc)?
Same question for the powered devices - if a device outside of the enclosure is being fed by this 24VDC source, does it also need to be listed? My take on PoE is that at least the device would need to be listed per 725.160 since power and data are coming in on the same line, but if power is separate from data would it need to be?
