running into a dimmer issue. using incadecent bulbs on fixtures and some 6"can lights.
the problem i'm having is these dimmers are generating heat and can be felt on the installation screws and the faceplate screws.
i see (now) that they have to be down sized (basically) with additional dimmers in same gang box.
so how can i correct this heat issue? do they make a larger wattage dimmer? i'm using some with 800w and some with 600w...(if i remember correctly)
thanks!
thanks!
