buffalonymann
- NC
I have XFMR 480:240 delta-delta. Installed 3 pole contactor to open 3 phases feeding resistive loads via solid state relays. The secondary side of the delta is not grounded, and I need to monitor the contactor poles so that when the contactor is opened, must verify there is no voltage on load side of contactor (in case on of the contacts weld closed). Initially thinking about putting 240VAC relays L1 to T2 - L2 to T3- L3 to T1. Problem is that if SSR is shorted current will flow through heaters and burn out relay coil. Was looking at Schneider CB but lowest value is 0.5A - the relay coil is 4mA. Looking for input
