Need help with 2 calculations and code references if you could please.
First one.Equipment terminations provided are 75c and type THHN copper
conductors in conduit are to be used.The service is a 3 phase with 200
amps for each ungrounded conductor.What is the minimum allowable size
of the ungrounded conductors?Second one.A 240v,single phase branch
circuit will supply an electric furnace that has elements rated at 12 kva
and a motor rated at 1.5kva.Equipment terminations provided are 75c
and type THW copper conductors are to be used.What is the minimum
allowable size of the branch-circuit conductors?
Thanks in advance for your help.:smile:
