PORTS
- Piketon, Ohio, USA
I have a LOTO question. Here is the scenario:
We have a boiler that we are doing the annual PM on. The PM is done in two parts, the first part is performed under LOTO where the 480V is locked and tagged out. The second part requires the boiler heaters (480V) to be de-energized, but the 120V control power to be energized. It is checking the level gauges, and if the heaters come on, they will try to control the gauges instead of the controlled pressure being applied. For this, the 480V heater fuses are pulled (the cover is off, exposing the heater connections), and the LOTO removed. An EEWP is in place to allow the lifting and landing of 120V leads on the gauges and adjustment of a rheostat as needed.
My question is, do the heater fuses need to be "controlled", ie, placed under LOTO.
I think they do, but there are people arguing that since the fuses are not being pulled to protect personnel, they do not need to be under LOTO. But, if I do not control them, how to I ensure that a zero energy check is done on the exposed heater connections?
Thank you in advance for your help.
