How critical is it to keep load balanced. The loads on a 3 phase panel vary from 10-15 amps. Some loads are 2 pole and some single pole. I can move around the breakers to balance load but is there anythey NEC that says it has to be balanced.
2nd Q. Is there a NEC reference to bring in two different power sources into a piece of equipment? I have two 120/208 power sources into one piece of equipment. The panel is over loaded feeding the original equipment so they brought in another set of circuits from a different panel into equipment. its the same voltage just different sources. anyone see a violation per NEC
