How would one go about doing load calcs for non existent residential structures? Here's the situation: Residential property, will eventually get a 3600 sq/ft house, a 600 sq/ft ADU, a ~1000 sq/ft garage, a small pool building with bathroom,1x electric car charger, and a dedicated utility building housing electrical (service, ATS, generator distribution panel, panel for outdoor circuits, lighting controls, solar inverters, space for batteries maybe) and data. These structures will be designed and developed over time. I want to get the electrical service in at the start of the project, then feed the buildings from it as they're built. Service would be a 400 amp switchboard w/ 600 amp buss. PoCo obviously wants plans and a load calc. What should we do? Make a load calc based on assumptions of what would go in the buildings?
Also, is there another term for the small padmount transformers used in residential distribution? Lines are overhead, there is 5kv on the side of the property I want the PoCo to use one of these small padmounts and feed the service underground as we're trying to not have a giant pole mount transformer in the yard. Mentioned padmount to poco engineer and he started this tirade about clearances, room for a crane, 8ft clearance with bollards around all sides of the transformer which sounded more like for the larger commercial service padmounts, not the little 25kva ones that can be placed with pretty much anything.
