I am calculating the loads for a new extended stay facility. All the rooms are suites with separate sleeping areas and cooking facilities. Each unit has a small cooktop, dishwasher, disposal and bar type fridge. There is no separate water heater. Hot water is supplied by the motel central HWH. The heat/cool is an under window combo type. Since this meets the definition of a dwelling unit do I have to compute the suites area as I would an apartment house with a minimum 100 A service in each unit. It seems to me there is an exception to this which allows the unit panel to be reduced to 60A.
Am I correct?
Thanks
Am I correct?
Thanks
