Load calcs
Veebee
New User
California
Designer
I have a heat pump with MOP:50 and MCA:40 and KW:16. How do i calculate the FLA and KVA.
What's the relation between FLA and KVA. and what goes on panel schedules.
Thanks
Thanks
There should somewhere be a nameplate that tells you the system voltage and FLA.
You would use those numbers to calculate the kVA.
Just out of curiosity, what kind of designer are you?
