A customer has a four plex apartment building and wants to replace existing gas ranges with electric ranges in each unit. I did a load calculation on the feeders to each apartment (60 amp exists). Also on main service - 200 amp exists. I used 08 code Article 220.83 to compute. I don't know exactly what the load is on the house panel, but only lights in the basement and a couple of laundry circuits (Gas dryer), and a central boiler.
My first thoughts were NO WAY adding four electric ranges to existing 200 amp service, but after doing the load calcs??
I'm not sure if I calculated properly - any feedback would be appreciated.
Thanks!
Existing 200 amp service with (4) apartment panels fused at 60 amp and (1) house panel fused at 60 amp.
Each apartment: 650 square feet, and (1) kitchen appliance circuit.
Apartment loads: 650 sq.ft. X 3VA = 1950 VA
(1) appliance circuit = 1500 VA
Existing load: 3450 VA / 240 volts = 14.38 amps
Add 12.5 KW range 12500 VA
New feeder load: 15950 VA
220.83 ( 08 code) : 8000 VA @ 100% = 8000 VA
remainder at 40% 15950-8000= 7950 VA @ 40% = 3180 VA
Total: 11180 VA / 240 volts = 46.58 amps OK on 60 amp panel
Main service load (4) apartments @ 3450 VA = 13800 VA / 240 volts = 57.5 amps plus house panel
Add ranges (4) @ 12.5 KW 50000 VA
Total with added ranges: 63800 VA
1st. 8000 VA @ 100% = 8000 VA
remander @ 40% = 63800-8000=55800 X .4 = 22320 VA
Total: 30320 VA / 240 volts = 126.33 amps plus house panel OK on 200 amp service
Thanks!
