Load Center around a Sink
Just trying to find out the minimum distance an indoor 100a panel can be installed from a deepsink. Working with limited space...may become an issue. Thanks.
Re: Load Center around a Sink
close as you want as long as you have your 30 inches wide and 36 deep in front of panel and nothing from floor to ceiling
Originally posted by usernotfound:
That 30 inches wide...that's from the edge of of the panel correct? Thanks.
No, the working space can be centered to the panel, from left to right, or from right to left, and can even overlap the working space of other electrical equipment. Make sure you can also open the door, if included, to a full 90 degrees.
