wrobotronic
- Colorado
Hello,
Is there a code requirement to have a load connected to the load side of a meter housing? if said housing is not yet being used?
I have a 7-11 that has 3 more tenant spaces. All four meters (7-11 is using CTs) are tapped from a 1200A bus gutter. The one line is being redrawn to eliminate the panels at the other 3 units. It is only showing that the meter housings are being set and the line side of the meter connected. My gut tells me this is ok since no conductors are being installed on the load side of the meters and they are labeled as future use. Basically they are changing the One line to allow for the 7-11 to open and permit the other 3 units separately.
Thank you all so very much for your help as always,
Cheers!!!
Cheers!!!
