Brnspark
New member
- Salt lake city, utah
I have a 45 KVA transformer that is fed with 480 volt 60 amps, feeding a 125 amp Square D QO panel. I have been asked to replace a 50 amp 3 pole breaker with a 100 amp 3 pole breaker for a new piece of equipment we are getting. There are already 3 3 pole 30 amp Breakers plus a few 20 amp receptacle Outlets being fed from this panel. The 100 amp piece of equipment will be running the same time as two of the 30 amp ones. The panel is fed with number 2 wire. Just wondering if I can put that 100 amp breaker in. The equipment doesn't have an FLA on the nameplate, just what size overcurrent protection we need.
