Load Side Connection on Bus Duct Through plug-in unit?
Frank6172
Maryland
Engineer
Hi All,
The roof top level electrical room has a 800A bus duct protected by a 600A breaker in the basement electrical room and we have 120A total output current from all inverters. Per 2017 NEC 705.12 (B)(2)(3)(a) 1.25x120+600<800A so we should be able to do load side connection on bus duct. However, I have 2 questions: (1). Does plug-in unit on the bus duct have OCPD? The rooftop level electrical room is very tight in terms of space so I couldn't install any fused disconnect there with proper working space clearance. (2) Is the plug-in unit good for backfeed? here is the nameplate of the bus duct below.
In general a lugs only kit for the bus duct would be at thr full rating of the duct, so it could be significantly larger than a smaller OCPD. But check with your manufacturer.
... Per 2017 NEC 705.12 (B)(2)(3)(a) 1.25x120+600<800A so we should be able to do load side connection on bus duct.
Your listed busway (art 368) is really considered a wiring method, not distribution equipment. So I think you should be thinking of this as a feeder tap. So it's 705.12(2)(1)(a) that you comply with (math is the same). 705.12(2)(2) is a bit odd in the 2017 code and can be read as requiring your tap conductors to be rated for at least 247.5A, that is (600+120×1.25)×.33, if doing a 25ft tap. But you can use the tap rules so if you can do a 10ft or 25ft tap to a fused disco outside the electrical room you should be good. That is, you don't need the PV OCPD closer than that.
I'm not familiar with busway connections but assuming it's just a conductor termination and doesn't contain a protective device then it's certainly suitable for backfeed.
FPE has been out of business for awhile. Luckily this company provides parts: www.fpeparts.com
You might be able to get a bus plug switch or an OCPD to connect to the bus. Contact FPE Parts and see what they can do for you.
If you get a bus plug switch then treat the connection as a tap in 240 and 705. That's going to be a problem if you can't get to a fused switch close by. If you can get an OCPD then your utility is still probably going to requires a fused switch to have the visible blades.
If you get an OCPD then the bus duct bus can be treated as a really long bus in a SWBD. I would apply the same rules from 705.
While a busway is not distribution equipment, feeders and branch circuits taken off a busway with OCPD as in NEC 368.17(C) are treated as feeders and branch circuits from distribution equipment and not as tap conductors. I think it's reasonable to treat them the same as a connection to a SWBD bus through an OCPD.
