ELSLI
New member
- Medford,NY,USA
Scenario: A pool filter is tripping a 240V single phase GFCI Breaker. The breaker holds with no load on it.
Can any one suggest a good way to load test the conductors and breaker to rule them out as the cause of the problem. I don't like telling a homeowner to get a pump serviced or replaced if the problem is with the circuit.
I considered a 240V electric heater, not the most efficient thing to carry on a truck. I feel a load test on the conductors is the best test to rule them out. If the breaker still trips then I would suspect a conductor is failing under load.
Perhaps I am thinking this through wrong.
Thanks for any suggestion.
