Re: Loadcenters vs. Panelboards
Load centers use plug-on breakers and are generally 3-1/2"-4" deep with knock-outs, and up to 400a 240v, 1 or 3ph, with branch breakers up to 125A.
Panelboards are anywhere from about 5-1/2"-over 10" deep, 20" to around 44" wide, 36"-90" high depending upon the breaker sizes they are sized for, use bolt-on breakers (plug-on may be an option with the smaller breakers but not normally specified), ratings up to 600v, and the ones that I'm familiar with have no knock-outs. Many more options and modifications are available for panelboards. The components of a panel are more versatile in the way that it is assembled in that chassis only and other parts can be supplied to OEM customers as well as being able to be used in switchboards.
Panelboards are constructed differently but that doesn't mean that a loadcenter is any less quality with regard to a simple application as it too must meet UL requirements just as the panelboard does but be cautious of any Federal Specifications to assure that the loadcenter complied with them.
Unless the specifications specifically state the use of a panelboard, bolt-on breakers, as any other options not available with the load center, the load center should be OK to use.
