Electriman
- TX
Greetings,
I am installing a remote meter to measure the flow in a pipe. The meter is fed by a 20A, 120 VAC circuit from a remote panelboard. Do I need to install a local disconnect with in the sight of the flow meter to meet the NEC? I know NEC 430.102 requires to install a local disconnect next to the motor but I am not sure if that apply to none motor load?
Thanks in advance.
Thanks in advance.
