Locating a handhole
sparky1118
Massachusetts
Master Electrician
Does anyone have a trick or an idea as to how to locate a hand hole? I need to connect into it. The utility company said “it’s on the other side of the road” but they don’t know exactly where and I’m having a bear of a time trying to find it.
Sent from my iPhone using Tapatalk Pro
I would try a circuit tracer that is designed for underground work. You can probably rent one from a tool rental place. Something like this Amprobe.
Yep... if the handhole is overgrown I'd start with the tracer under the assumption that something (CATV, typically) has a squawker signal. If that doesn't pan out, just walk back and forth in the general area, poking into the ground with a glo-rod. The cover won't be deep.
Ah, no, no such thing. And geeze, if the utility company can't find it- they have the equipment. Just too lazy.
Regional? Someone rings up 811 (our free "call before you dig" service) and depending on who gets sent, I'll either see one color for everything, or different for electric, gas, and (only at the street) CATV+POTS. But yeah, you'd think the utility could do it. Maybe if MA has a similar call-dig hotline, sparky could ring that up and narrow down the search area?
MA has the Dig Safe service. Just call 811.
I believe it's national. So, yes.
-Hal
I believe individual states have adopted laws for this, but most if not all have done so. Don't know if there was any federal mandate that got it there or not. I know years ago if I called I got a call center within the state, now requests go to a center that handles many states. If you are actually still calling the center you need very good details as their maps are not always accurate and they can't find what you are describing. On line requests let you layout your own location area on an interactive map. However with some new projects the map isn't updated enough to lay some things out and knowing a GPS coordinate of key points can be helpful to be more accurate.
