I've had to locate a lot of buried receptacle and switch boxes, usually without too much difficulty.
Usually you know the height of the box, and with a 4-foot straight edge you can pivot on the high spot. Also use a stud finder to pinpoint the stud nearest your pivot point to fine tune where to drill a 1/8th inch hole with a feeler bit.
Today I had a smoke detector outlet box buried in the ceiling. The straight edge can find a slight high spot, but not an exact spot. We usually just nail up smoke detector boxes wherever it works best and doesn't interfere with the lighting lay-out, so I don't have a measured reference point to go off of.
I don't want to start cutting into this persons nicely textured ceiling until I have a better idea of the location.
Is there any way to trace a specific wire behind sheetrock? What about the greenlee cs8000 circuit tracer? I know it's kind of expensive, but I've been kind of thinking about this tool for other trouble-shooting purposes but don't know too much about it or if there's other tracers that would be better.
I would be interested in hearing any other techniques or methods that others use.
Sky
Sky
