location of circuit breker
sleepy
working clearance for a 400 breaker
i have a question, can you put the breaker above a c/t cabinet.
i know there is working clearances around panels.
does the code say ok. thanks for some help
sleepy
Will it comply with the following?
240.24 Location in or on Premises
(A) Accessibility Overcurrent devices shall be readily accessible and shall be installed so that the center of the grip of the operating handle of the switch or circuit breaker, when in its highest position, is not more than 2.0 m (6 ft 7 in.) above the floor or working platform unless one of the following applies:
(1) For busways, as provided in 368.12.
(2) For supplementary overcurrent protection, as described in 240.10.
(3) For overcurrent devices, as described in 225.40 and 230.92.
(4) For overcurrent devices adjacent to utilization equipment that they supply, access shall be permitted to be by portable means.
