Hello,
I am installing a transformer with a 208V single phase primary and 240/120V secondary. It is being fed from an existing panel. The transformer will then feed a new panel.
Also, there will be a manual transfer switch to allow a standby generator to be connected to the panel that will be fed by the transformer. The generator will be 240/120V.
When I install the fused disconnect on the secondary of the transformer, should it be installed before or after the transfer switch?
Thanks!
Thanks!
