Dab123
- Rogers, AR
- Electrician
Where I live the electric company has now started putting the meter on a pedestal away from the houses, we generally run an SER cable from our panel in the houses to the outside to a disconnect on the wall. As many of you may know there is a shortage of 200 amp disconnects right now so we have started putting a NEMA 3R junction box on the house where a disconnect would normally be located and running our underground lines from there to the meter can which has a 200 amp breaker in it. My question is that since it is within sight does this meet the code or are we required to have the additional disconnect on the house?
