bjp_ne_elec
- Southern NH
Again, I know I've said it before, but the residential game is new to me - and I'm back in the trade after a 15 year abscense.
On a new house, where do you guys generally install the ground rods? My home , and most I've seen, have the ground rods driven outside. Generally wire penetrates side of house, just below meter socket, and the ground is routed down in to the earth. Others, I've seen the ground rod (or rods) driven in the basement. My concern about the basement is one of possibly creating a spot for water to penetrate in to the basement.
I know you have to put a grounding bushing on the end of a metal conduit (although on my house - which is 20 years old, and I didn't buy it new - the ground wire just snakes in to a 1/2" EMT, and it has no grounding bushing), but do most of you end up with a situation that requires the the Grounding Electrode Conductor (GEC) to be installed inside EMT?
(Doing a little researching after posting this - I came upon this ( http://forums.mikeholt.com/showpost.php?p=649540&postcount=23 ) and am confused. The sketch shows the GEC going in to the meter socket. What situation would put you in to the meter socket with the GEC?)
I know I'm big on pics - but one photo captures so much - do any of you have any good pics that show how you've tied the grounding in? This to include ground rods (in NH, PSNH requires two), the routing of the GEC and any bonding.
Now this house has the plumbing roughed in, all I see is plastic (white) piping, with the only copper being some short peices at where the sinks would be. My question is, what do you do in this case, to bond to the "water piping". This system is on a well, so there obviously won't be any meter. Actually when I bid this job, it was indicated to me it was "city water" - but that's a whole other story. Also like to pics that some might have when dealing with plastic water piping - I'm assuming there's going to be some copper around the pressure tank, etc - but maybe not.
Thanks,
Brett
Thanks,
Brett
