natfuelbill
250.24(A)(1) requires the Grounding Electrode Conductor be connected to the Grounded Service Conductor to be connected at load side of service drop, or meter enclosure or in service disconnecting means.
For a situation with a system with a full-capacity backup generator. The generator is not a separately derived system and the ATS is 3-pole.
1) Can this NG connection be located in a downstream ATS (automatic transfer switch) immediately after the service disconnecting means?
2) If yes, what NEC section allows this location?
