I am installing a circuit in my place of work to have the computer server room hooked up to an emergency generator. I will be using a 15 KVA transformer to step the voltage down from 460 VAC to 208 VAC. The circuit will be about 450 feet long from the generator panel to the server room. Can I locate the transformer at the generator panel,Or do I have to have the transformer located closer to or in the server room ? Also,Do I need to install a ground rod for the transformer ? Thank You for any info. Thanks,Steve Wiese.
