Greetings,
I have control enclosures that contain breakers and motor starters that will need to be locked out individually. The motor starters are ABB, MS series manual motor starters coupled to ABB contactors. These units are designed to be individually locked out. I also have ABB breakers inside the control enclosure that will be locked out.
My question: Is there a insulated type of lock that can be used instead of a metal lock? The motor starters are mounted on DIN rail and are located right next to each other, so there is a concern of accidental contact with energized parts.
Thank you for your help.
Matt Wolf
Matt Wolf
