Is there a lock out tag out device that is listed for an occupancy sensor switch?
JJWalecka Senior Member Location New England Apr 27, 2017 #1 Is there a lock out tag out device that is listed for an occupancy sensor switch? Attachments KIMG0735.jpg 164.6 KB · Views: 0
P petersonra Senior Member Location Northern illinois Occupation engineer Apr 27, 2017 #3 I think you would have to use the BC OCPD.
JJWalecka Senior Member Location New England Apr 29, 2017 #4 petersonra said: I think you would have to use the BC OCPD. Click to expand... Ended up just locking out breaker. I had hoped there was something out there that I could use.
Coppersmith Senior Member Location Tampa, FL, USA Occupation Electrical Contractor Apr 29, 2017 #5 If you are worried about inconveniencing people in other rooms on that same circuit, you count turn off the breaker, disconnect the hot from the switch, cap it off, turn the breaker back on. When you're done working, just reverse the process.
kwired Electron manager Location NE Nebraska Apr 29, 2017 #6 JJWalecka said: Is there a lock out tag out device that is listed for an occupancy sensor switch? Click to expand...
