schwarz633
- WI
I'm rewiring a machine where the OEM has used red Loctite on all of the C1D1 threaded conduit connections. I've had to use a torch to disassemble every threaded joint. Is this normal?
I agree with what Bob said.
Assuming "Locktite" was used to lock threads more so then to seal them, and red is the strongest version - they must not wanted it to come apart, though a little time and a little oxidation usually locks them quite well enough anyhow.
Hope the area wasn't "classified" at the time you were using the torch to disassemble it.
LocTite is a brand name.
They make thread locker and they also make anti-seize.
IIRC correctly, red is the thread locker and the anti-seize is silver (or is it blue?). I also believe they have started making sealants which seal but neither lock nor inhibit locking.
Can you contact whoever built that and ask them what this is on there and why?
If it's wrong and nobody ever questions it, they're just going to keep on doing it.
