Log Home boxes
Jerseydaze
Anyone know of any boxes I can use for Log siding on a new home would like to install before logs are installed for coach lights and gfis with bubble thanks
Round or octagon metal boxes for the lights and. metal handy gangable boxes for outlets and switches. This gives you lots of options for mounting with screws.
Youy can use whatever box you normally use. You just need to coordinate with the crew that's installing it to make sure that 1. it's installed in the middle of a course and 2. you have a flat spot for the fixture to set against.
If you can get the builder to install a block for you at each light and recept. location it will make life easier for you and clean looking installation. Like the others said an octagon box w/ ears is your best bet for the lights. Just holesaw your box in.
