chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
I'm still looking for sockets for torque wrenches that can reach deep to the lugs of large molded case CB's. Thanks.
Not if you're careful about keeping the torque applied about the turning axis.Pierre C Belarge said:I am wondering if using a longer Allen key that is not designed for the torque wrench would have any effect on the actual torque value?
mengelman said:Where have you looked?
Well, technically speaking, since you don't want the 90, you want to cut off the long side, and use that.infinity said:Take an "L" shaped Allen key and cut off the short side.
