mstrlucky74
- NJ
I see these asked for a lot for underground work? What's the longer sweep for(or help) and where is the sweep measurement take from...say 36" or 60"? Thanks.
i believe that the 36" or 60" figure refers to the radius of the curve at the centerline of the pipe. That also gives you the approximate perpendicular offset of the end of one straight piece to the end of the other.I see these asked for a lot for underground work? What's the longer sweep for(or help) and where is the sweep measurement take from...say 36" or 60"? Thanks.
And what is the minimum sweep per NEC?Yup, I see that and I use factory standard elbows when they make that statement. It is rare for the Engineer that writes such a lazy spec. to visit the job, but if one did and attempted to insist I provide a longer radius elbow, I would require a change order. "long sweep" does not define anything. The sweep is longer than the minimum sweep of a standard elbow as required in the NEC. If they want a specific sweep they need to specify a specific sweep.
Sent from my SM-G955U using Tapatalk
I thought you used the 60 if you were worried about sidewall tension due to size of conductor... the 60 offers an easier sweep to pull the wire through.
According to the friction theory that is used for calculating pulling tension, the pulling tension is independent of the bend radius. What causes a larger sweep to help?
I thought extra large radius bends help with reducing sidewall pressure, but have no effect on pulling tension.
