Bam-Bam
New User
- Tehachapi, CA
- Firefighter
Preface: I tried to search on here for an existing thread answering my question, and turned up more confused then when I started.
Would the 83% rule apply if i wanted to run a feeder line to a 100 amp sub panel for an accessory dwelling unit (ADU)? My confusion in interpretation of the code. The feeder will be supplying the entire load for the ADU however it is obviously not the entire load for the main dwelling (my house). The feeder will only be used for the sub panel load.
