Looking for a 3 way capable vent fan timer
Volta
Columbus, Ohio
Not offhand, but maybe a one-shot timer with the input fed from multiple N.O. momentary push-buttons? Another wire can be fed through adjacent N.C. buttons for a stop control.
c2500
South Carolina
A bath fan can be turned on at two locations. The HO wants to have a timer so the fan will keep running for some period of time.
c2500
Cold Fusion
way north
If you don't have to turn it off from the other location that you turned it on from - just put in two timers, one at each location. Wire the contacts in parallel.
If you have to be able to set the timer from one location and un-set it from the other location, that gets a little more complicated.
What exactly are the operations scenerios?
cf
